3 minutes ago, emilyadella said:
The case acts as the heatsink.
Wait What!?
how do you intend to move the heat from a GPU and CPU to the case?
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/776486-tiny-cube-build/#findComment-9793735
3 minutes ago, RadiatingLight said:
Wait What!?
i didnt wanted to say that i may point him or her later after the list she or he may be a newbie
My personal Build as i am a cool tech enthusiast B|
https://pcpartpicker.com/user/TheSneakyRM/saved/
https://linustechtips.com/topic/776486-tiny-cube-build/#findComment-9793746
1 minute ago, rrubberr said:
If he plans on only using 240 watts, the GPU is going to look something like this.
Heck, my computer with one of these and a Pentium 4 had a 340 watt power supply. I have no idea how you can think that a case is going to supply sufficient cooling. He'll probably end up with something along the lines of a 1050 passive cooled, or if he really needs a tiny GPU drop to something like a 730 or 750ti (eesh).
lol a 500 watt PSU is must he or she is new i think so ppl are used get overkill PSUs and he or she got an overdead PSU
https://linustechtips.com/topic/776486-tiny-cube-build/#findComment-9793753
3 minutes ago, rrubberr said:
I didn't realize how tiny 1050ti's could be! Look how cute that is.
https://www.newegg.com/Product/Product.aspx?Item=N82E16814137081
that looks shit even an EVGA or Zotac one mini card could be better
https://linustechtips.com/topic/776486-tiny-cube-build/#findComment-9793771
as note since everyone is guessing all over the place it is she.
2 not so new but it has been a while
the case I want to build in is the stream com DB4
The max psu they sell for this case is a 240watt so I was leaving 20watts of over head
it is mini itx compatible and features a pci-e 16x riser to mount the card behind the motherboard
as far as the cpu I was considering the low wattage intel Intel Core i5-4570T
I would like to have moderate gaming performance and was considering a 512gb m2 drive
https://linustechtips.com/topic/776486-tiny-cube-build/#findComment-9793814
i said make the build in PC parts picker and why an 4th gen cpu in 2017
https://linustechtips.com/topic/776486-tiny-cube-build/#findComment-9793817
2 minutes ago, emilyadella said:
as far as cpus I was not aware the 6600T came in 35watt variant
I located that now and would go with it I know it is 6th gen but I have yet to find a decent 7th gen process that will compete
https://de.wikipedia.org/wiki/Liste_der_Intel-Core-i-Prozessoren
the i7 goes all the way down to 15W
https://linustechtips.com/topic/776486-tiny-cube-build/#findComment-9793857
I would go i7 7700t then which is another 35watt variant however it is not on pc part pick either
My main concern with this build was to power a 35 watt cpu, mid range mini-itx cpu and gpu that could run games in the line of metro last light in 1080p at about 45fps while not melting anything. within the 240 watt maximum
https://linustechtips.com/topic/776486-tiny-cube-build/#findComment-9793876
but why the hassle to get this case if you want to game? If you want to use a gpu in this case you have to create airflow which will completely destroy the reason it is built this way, which is to have no airflow and therefore no noise.
https://linustechtips.com/topic/776486-tiny-cube-build/#findComment-9793884
4 minutes ago, emilyadella said:
It is a lot bigger and uglier is the problem if I was going to build something close to that size I would build in the Dan case A4 sff
https://www.dan-cases.com/dana4.php
because then I would not have near the limitations
that sounds a lot more reasonable for a gaming build.
https://linustechtips.com/topic/776486-tiny-cube-build/#findComment-9793926
9 minutes ago, emilyadella said:
I did find a wattage list the internals on this would like this though I do know if if a 1050ti would run metro at 45fps
part list if I was doing this build gpu is passively cooled
https://pcpartpicker.com/list/7dbyBP
no this is not ok - you cannot use a passive cooled gpu in a case without airflow.
https://linustechtips.com/topic/776486-tiny-cube-build/#findComment-9793996
