GPU Decision Help
Go to solution Solved by apaydinabdul,
Don't worry, you'll be fine with that GPU for all those games at 1080p with even a couple of settings turned to high or very high.
Though I assume you play at 60Hz
I am building my first gaming computer, but I'm on a budget. After doing plenty of research on cheap, reliable GPU's, I have decided on the EVGA GeForce GTX 1050 Ti SC. I was wondering if this would be adequate for me, since I'll be playing games like Fallout 4, GTA V, CS:GO, COD WAW. Please keep in mind that I'm fine with turning down settings to minimum if necessary and all help is greatly appreciated.
https://linustechtips.com/topic/776365-gpu-decision-help/
