So.
I bought and installed new ram,
My computer is messed up. My temps are broken. My Audio is broken. My fans are messed up. Keyboard is messed up.
So I go into my bios click load optimized defaults and save and exit.
Go into windows and I can see that it has not reset because my ram speed and CPU OC are still messed up.
How do I completely reset my bios? because load optimized defaults is not working
CPU 6700k
Motherboard z170-AR
Ram: Tridentz RGB 3000mhz
GPU: EVGA 980 FTW
https://linustechtips.com/topic/776342-motherboard-wont-load-optimized-defaults/
You could clear cmos by removing the motherboard battery waiting 15 minutes and putting it back in. I would do that as last resort though.
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
