Help
Go to solution Solved by Electronics Wizardy,
Your not gonna get a big server in there
Normally with short racks you only mount it by the front ears as the short stuff doesn't weigh much.
So i bought a server rack to house all my hardware in and i didn't notice that it was a short depth rack. i cant send it back so i intend on using it but i cant find any rails that will fit it. Any suggestions for good cheep rails that are only 16in long and can hold 100+ lbs of server hardware? Thanks.
Iink to rack.
http://www.ebay.com/itm/12U-IT-Wallmount-Cabinet-Enclosure-19-Server-Network-Rack-W-Locking-Glass-Door-/380770754096?hash=item58a7b49e30:g:450AAOSw9eVXV4dg
https://linustechtips.com/topic/776340-help/
Well i can fit a atx board in there and i don't feel good about having a Norco short depth case with hardware mounted by the front ears.
https://linustechtips.com/topic/776340-help/#findComment-9792193
