I've currently got a 1080 running a 165hz 1440p monitor and I've noticed that my frames sometimes go as low as 50 when gsync is enabled on battlefeld 1, whereas all benchmarks I've looked at on the internet are showing minumums of 90fps. Are the benchmarks wrong and my card just isn't strong enough? Or is there something possibly wrong with my card?
Thanks,
Coldris
EDIT:
ROG ranger 7
16Gb 1600Mhz Ddr3
4790k
750W Corsair PSU
Windows 10
Unsure about the rest of the build
Edited by Coldris
Extra info
https://linustechtips.com/topic/776107-fps-problems/
i have a 4770K at 4.2ghz and a GTX 1080 around 1950mhz and it destroy battlefield 1 at 2560x1440 on the ultra preset i get anywhere from 90 to 135FPS depending on the map and locations, in multiplayer.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/776107-fps-problems/#findComment-9790259
Is DSR on by any chance in your Nvidia drivers? Also what resolution scale are you using in game?
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/776107-fps-problems/#findComment-9790269
