Specs:
cpu: AMD R5 1600x
cooler: corsair h110i
mobo: Gigabyte ga-ax370-gaming k7
ram: g.skill ripjaws V 3200mhz
gpu: evga gtx 1060 ftw 6gb
hdd: WB blue 3tb
ssd: samsung ssd 750 evo
ps: evga supernova nex750b
so the problem that ive encountered is that yesterday the system was working just fine running the "F2" bios version. i turned it on today and gigabytes appcenter software let me know that the "F3" bios was available to update and i let the software update the bios to the F3 version, i restarted the system to let the changes take effect but now the system wont post on either bios (this is the dual bios board) and the lcd panel at the bottom is only showing the error code "0d". ive tried clearing the cmos, switching bios, unplugging and only using one stick of ram but the thing will still not work.
any help would be appreciated.
https://linustechtips.com/topic/776047-system-wont-post-after-bios-update/
Since you have updated your Bios from Windows, you should not have a bricked Motherboard. MAYBE  the problem is the frequency of the RAM, i would suggest to try using a lower speed one if avaible, or look around if you can see a flash bios button to restore an older BIOS. I Know in some ASUS board there's one with an associated USB port where you can simply connect a USB containing the BIOS file then you click this button and it auto-flashes the BIOS.
This was a very bad explaination :)
0D or D0?
0D doesn't exist in your boards manual and D0 means CPU Failure.
Main Rig:-
Server:-
