Scarlett 2i2 Help
Go to solution Solved by Enderman,
Yes the scarlett interfaces can output windows audio like normal speakers.
(I'm a noob)
I already have the Scarlett 2i2 and have been using it with some headphones and an XLR mic to record my guitar, however I wish to get some monitors to go with them something like the M-Audio BX5. My question is can I plug them straight into the interface and use them as regular speakers (I will continue to use my headphones for direct monitoring), so I can watch YouTube with them and listen to music?
Thanks
https://linustechtips.com/topic/775615-scarlett-2i2-help/
https://linustechtips.com/topic/775615-scarlett-2i2-help/#findComment-9784209
