Hey , so my pc has a 6700k for a few months now on a Asus B150 pro d3 (not the gaming one) and i was able to change the core multiplier (etc) of the cpu , but now i cant . And i also wanna add that i didnt do any bios update since or in that period.
I know i should change the motherboard but its not in my budget at all right now thats why im asking what could have happened in these last few weeks :/ Thanks !
https://linustechtips.com/topic/775511-help-with-mobocpu/
I think you changed the BCLK?
But you aren't supposed to be able to change BCLK or multiplier anyways on B150.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/775511-help-with-mobocpu/#findComment-9783079
  • 3 weeks later...
Sorry for no response , no , i did not but i am able to , and as i said , i was able to change the multiplier aswell but now i cant (with no updates installed on it from then )
https://linustechtips.com/topic/775511-help-with-mobocpu/#findComment-9872467
