Noob question for web devs
Solved by leonfagan71,
Just now, Ranz said:Hello thanks for the reply and help!
is that the minimum i could install to solve my problem?
I have used Xampp in the past and I find it to work well for small dev things.
If you plan to use a database, you can allow MySQL to install, (it is selected by default)
but you'd need Apache with PHP and MySQL if you want it.
Regards,
Leon.
