Hello all, some advice needed about my friends rig
specs
i3 2nd gen CPU
Gigabyte H61 mobo
8gb ddr2
CM 500w PSU
Asus 24 1080p Display
here's the best one.... GTX 1060 6 GB VGA
what are your thoughts about this guys?? will something bad happen to the VGA?? is it okay to not upgrade? btw he can max out every game title up to now.
https://linustechtips.com/topic/775272-old-parts-new-gpu/
It's fine, the CPU will just hold the GPU back in many games.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/775272-old-parts-new-gpu/#findComment-9780056
The dualcore will likely hold the GPU back most of the time, but it works :)
GTX 1060 can play pretty much anything at highest settings at 1080p, but when the games become more CPU intensive, like GTA V you'll see the frames dipping.
Not becuase of the GPU lacking in horspower, but the i3 probably wouldn't be able to keep up.
https://linustechtips.com/topic/775272-old-parts-new-gpu/#findComment-9780082
4 hours ago, Spenser1337 said:
Should probably at least upgrade to a 2400 or even a 3770
2600 or 3770. That would be a 1080p or 1440P monster.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/775272-old-parts-new-gpu/#findComment-9781743
specs
i3 2nd gen CPU
Gigabyte H61 mobo
8gb ddr2
CM 500w PSU
If your using a LGA1155 socket try upgrading to a Intel Pentium G4560 3.5GHz Dual-Core Processor as well.
https://linustechtips.com/topic/775272-old-parts-new-gpu/#findComment-9781748
A G4560 requires LGA1151, and would be outperformed by an Ivy Bridge i5/i7, both would end up being cheaper upgrades.
PSU Tier List | CoC
https://linustechtips.com/topic/775272-old-parts-new-gpu/#findComment-9781753
I misread the socket type, but yeah unless you have a good mobo and can get a really nice processor for cheaper than it would cost to get a new mobo and G4560 then its a good upgrade to look into alongside the GPU.
https://linustechtips.com/topic/775272-old-parts-new-gpu/#findComment-9781844
It's not really that good of an upgrade compared to a 3570/3770 (which you could no question get for <$200), and even an H61 board can handle a 3570/3770.
PSU Tier List | CoC
https://linustechtips.com/topic/775272-old-parts-new-gpu/#findComment-9781860
