Random Drop in Avg Fps
Solved by Simon771,
1 minute ago, moocrew247 said:i made sure vsync is off, and usually 70-80 for gpu and 100 for cpu on bf1 (lower on other games). The usuage levels were the same before, kinda sucks tho now
I have been playing overwatch a bit, and I didn't notice any FPS differences in last few months.
You can try to reinstall games, or use DDU to reinstall GPU drivers. Also you can reinstall Windows and see if that solves the problem.
Not sure what else can you do. But if your CPU is at 100% load .... well that as much FPS as you will be able to get. Same goes for GPU.
