HI, guys, I'm building my first ever own PC, and i run into a lot of problem since I'm a begineer, I'm using a cooler master mastercase 5 and asus maximus IX hero MB, I was trying to get the wire connected, but I run into a lot of issues with connecting the front panel IO,
I'm not sure how to plug in these connectors, both the case and MB manual doesn't talk about these plugs, Can anyone offer some help please.
The following is the MB layout
Please help me, I'm so thrilled and frustrated
Thanks
https://linustechtips.com/topic/774704-first-pc-build-please-help/
The front panel headers go into the groups of pins labelled F_Panel at the bottom right of the motherboard.
12 minutes ago, Onepoundlion said:
Snip
If you cannot find it in the motherboard manual (its definitely there somewhere, but sometimes not in an obvious place, @Sors says 1-26), the pinouts are often labeled on the motherboard near to the connectors (in super small writing, but its there)... I know they are on the Z170-A and H170 Pro Gaming from Asus that i've worked with, so they will likely be somewhere on that Asus board as well (they were also labeled in the manual though, so double check that first)
THX, so I thik I just plug them in the F-panel section
Thanks
Check the pages
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
Just had to say, nice GPU! Is that a 1080 FTW?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
14 hours ago, Zyndo said:
it literally says 1080 FTW on it
Yup, just double checking and displaying my excitement over it by asking if it's what I though is was, kind of like when someone gives you a present you've been wanting for ages and you say, "Really? For me?".
Mouse: EVGA X17
On 2/5/2017 at 9:44 PM, Onepoundlion said:
Does the PLED + and -matters?
Those are the leds, and they only light up if you plug them with the correct polarity, nothing is damaged if you plug them backwards, the lights just don't turn on, you can reverse the connector if it doesn't work, the motherboard usually have the + pin marked.
Mystery is the source of all true science.
