Ok so this build I called Project Unknown because some of the things with this system I had never seen or heard of really. I truly believe I got an amazing deal on this system and I hope everyone enjoys it.
This is what my ststem looked like when I first got it. Nothing fancy running straight distilled water. With nasty looking lines.
Parts List:
CASE: Corsair Obsidian 900D
CPU: i7 5820k
CPU WB: XSPC RAYSTORM 3
MB: Gigabyte X99 GA-Gaming 5 (ver 1)
RAM: ADATA XPG Z1 DDR4 (2x4GB) ( Don't know the Mhz )
GPU: Gigabyte Windforce GTX 970 4GB
GPU WB: EKWB FC Solution FC970 GTX WF3
PSU: EVGA 1300w SuperNOVA G2
NZXT SENTRY 3
BASIC DVD RW DRIVE.
Koolance 480mm Rad
XSPC 360mm Rad
XSPC Photon 270mm
D5 Pump
11 Cosair SP120
4 Corsair LED fans. ( dont know what model they are )
Qnix 27in LED 1440p
Razer Deathstalker Elite (the one with the screen on the 10 key pad)
Thermaltake m1000 Mouse
Some bluetooth microsoft keyboard and mouse
Zalman Case ( the one where the top fins open up)
Bitfenix Case ( the one that has the LCD on the front)
Google Pixel 32GB
LG G5 ( Bricked )
I guess that is it. I got all of this for $500. Guy i got it from just didn't want the stuff anymore and he was moving to upstate NY so score for me. So after getting it home and looking at it, i decided the guys runs were ugly as hell. i mean litterally lines were too long and just flopping around. I also noticed when i got it home how filthy it was on the inside from all the dust. So began the teardown of the system. (Wish I would have taken pictures.) but i cleaned everything. Had to order a replacement mounting kit for the Raystorm v3 because he installed it wrong and it was missing a spring. Well got the repacement mount in today and began the reassembly. ( I did clean everything.)
CPU BLOCK AND TOP RAD INSTALLED.
GPU AND RESERVOIR INSTALLED.
LOWER 4 X 120MM RAD AND FANS INSTALLED.
SYSTEM PLUMBED WITH PRIMOCHILL ULTRA CLEAR,
LONG LINE FROM THE CPU TO THE LOWER RAD HIDDEN WITH THE WIRE MESS THAT I GOTTA CLEAN UP. GOT THE IDEA FROM LINUS IN HIS ULTIMATE OVERKILL WATER COOLING GUIDE.
SIDE PANEL ON WITHOUT THAT STUPID ROGUE LOGO AND GEARS LOGO.
BACK SIDE PANEL FITS PERFECTLY NOT PINCHING ANYTHING...SO MUCH SPACE BEHIND THE MOTHERBOARD.
FRONT OF THE CASE. NO MORE DIVISION LOGO THERE.  GOTTA REMOVE ALL THE STUPID LOGOS FROM HERE SINCE I FORGOT.
WELL WHAT DOES EVERYONE THINK!!!!
CPU: Ryzen 7 3800X RAM: 32GB Corsair Vengeance PRO RGB SL 3600mhz GPU: RTX 3060TI SSD: WD Black 1TB NVME SDD: WD Black 500GB NVME
https://linustechtips.com/topic/774259-project-unknown/
