2 minutes ago, JDE said:
There are cheaper 3200mhz chips, SL308 is cheaper and PSU WHYYYYY
At least you were not using the Supernova NEX
And BTW the last post the G2/G3 650W are cheaper.
I was gonna change the ram to two sticks of 8gb kingston fury black ram but saw the trident to be cheaper so I didn't change it.
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760437
There is something called price filter. The Ripjaws V kit is cheapest
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760441
1 minute ago, Bidon said:
https://pcpartpicker.com/list/dtKzgL  <--- This is a really solid 1080p 60hz build
Oh god that horrible PSU and also oh god that RAM
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760456
35 minutes ago, Luke m said:
1 just built one for abou 900 this is all you need no more.
Https://pcpartpicker.com/user/lllk4/saved/q3R6hM
Belive me more is just blowing your money
Ps.
I dont have the ssd and runs perfectly fine
That is all over the place. You are overspending on the SSD and Motherboard. The case looks crap and the psu is only average.
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760462
good loard 8gb 2x4.
? Its only 2400
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760465
1 minute ago, EasonIDontKnowAnything said:
the problem is not only is it 2400. It's 2x4gb and tragiic wants to play csgo ( which 8 gb is fine yeah yeah ) but he also wants to stream
Ahhhhhh....
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760480
I'm not trying to say otherwise but, just asking, is RAM that important for streaming?
I'm not into streaming and I have 16GB but now I'm curious :P
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760486
Lets see , if you have 2 gb that's not happening. 4GB ok? 8GB is fine but 16 is the sweetspot for games and etc.
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760491
I would consider 8GB the sweetspot for gaming and 16 for streaming, editing and recording.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760498
Thanks! I do editing, rendering, game dev, etc so I really use my 16GB
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760513
I still remember when 4GB was acceptable ('13-'14)
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760524
Something like this would be fine.
The Ram might clock down to 2933MHz. You can look through the compatibility list on the mobo website if you want a kit that has been tested.
I didn't add a monitor but there is some money left if you want one. A RX580 (Or RX 480) is enough for 1080p and the R5 1600 has 6 cores which will help if you want to stream on twitch etc.
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor  ($217.55 @ OutletPC)
Motherboard: Gigabyte GA-AB350M-Gaming 3 Micro ATX AM4 Motherboard  ($93.89 @ OutletPC)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($126.99 @ Newegg)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($93.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.66 @ OutletPC)
Video Card: Sapphire Radeon RX 580 8GB PULSE Video Card  ($231.99 @ SuperBiiz)
Case: Cooler Master MasterBox 5 (Black) ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($66.89 @ Newegg)
Total: $938.85
Generated by PCPartPicker 2017-04-30 14:22 EDT-0400
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760527
Total: $938.85
RX580 for streaming? 1700 is better.
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760536
That one was the one given to reviewers by AMD, but there are cheaper 3200 kits that are on compatibility (Ripjaws V)
2 minutes ago, lee32uk said:
I would prefer the G2/G3
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760539
Just now, lee32uk said:
What ? The RX 580 is a gpu. Also I left the build with money left over in case he wants a good 144Hz monitor which he mentioned at the end of his initial post.
Im saying that I dont think the 580 is good for streaming (thought I might be wrong no hate pls) and I also meant that it should be a 1700 not a 1600
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760546
The Seasonic G is a solid psu. Of course the op can go for the EVGA if he wants but there is no real need to spend more money.
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760547
Streaming really depends on the CPU nowdays, and the 1600 should be enough. But 1700 would be better.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760548
Eh, I'm just rambling about the ugly cables
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/773607-i-need-help/page/2/#findComment-9760551
