Custom Cable Sleeving
8 minutes ago, Storm10 said:
Where should I go for custom cable sleeving?
There are lots of options these days if you want completely custom designed cable designs Cable Mods, Icemodz, Mainframe customs, Pexons to name a few.
https://linustechtips.com/topic/773420-custom-cable-sleeving/#findComment-9758443
@Storm10 check out CableMod, we have a wide variety of options in the U.S. from Amazon, Performance-PCs, NewEgg. You can also purchase directly from our global store or EU store if you're the EU.
https://linustechtips.com/topic/773420-custom-cable-sleeving/#findComment-9761907
