MSI Afterburner Core Voltage (mV) to Core Voltage (%) for Pascal GPUs
Solved by McHox,
1 minute ago, JurunceNK said:That's what I've got, along with voltage monitoring. Right now the voltage setting is set to "Reference Design" while I have Standard and Extended MSI, as well as Third Party. I tried all of them and I still don't have voltage control unlocked.
switch the tool or wait
2 minutes ago, Jrock said:
My 1070 works fine with 4.3.0...
In settings make sure you select "unlock voltage control"
as i just told you it's just the case for the 1080ti...
