Hello everyone
I am trying to build a system for a friend and am currently trying to make it as cheap as possible without buying used parts.
At the moment I have a complete build but would like some feedback to find out if I can further reduce the price (without decreasing performance)
These are the current parts:
Motherboard: ASRock H110M-DVS R3.0 (52.14€)
CPU: Intel i5 7400 (174.84€)
Graphics Card: MSI Geforce GTX 1050 2G OC (118.18€)
RAM: 8GB Crucial DDR4 2133 CL15 Single (53.04€)
PSU: Corsair CX450M (51.85€)
Storage: Samsung 850 Evo 250GB (90.71€)
(Cooler: Noctua NH-L9i, only if the stock cooler is not sufficient)
I would appreciate any help and feedback. (Do note that I am from Austria which means that the prices you propose may differ)
https://linustechtips.com/topic/772697-looking-for-help-building-a-system/
2 minutes ago, Jubsi said:
Posted the topic early by accident and it now shows current prices and I would like to get feedback on how to reduce the current costs.
Total budget please in €
so i would get a Pentium g4560 with a b250 motherboard if you are going with a gtx 1050. the reason for this suggestion is because you wont see a performance difference with the gtx 1050 paired with a Pentium versus an i5
Shouldn't i take a Quad Core?
https://fr.pcpartpicker.com/list/4Wgff8   ignore i clicked the wrong cpu
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
not with that gpu. the quad core wont give you better performance in games when paired with a low end gpu. you would need a rx 480 or above to start to see a difference between the two.
https://fr.pcpartpicker.com/list/34xvkT this is on France pc part picker
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
@Jubsi
Slightly over but a great budget combo. your budget doesn't allow for a quad core it doesn't leave enough money for the gpu.
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  (€64.57 @ Mindfactory)
Motherboard: ASRock B250 Pro4 ATX LGA1151 Motherboard  (€94.01 @ Mindfactory)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  (€54.19 @ Amazon Deutschland)
Storage: ADATA Ultimate SU800 128GB 2.5" Solid State Drive  (€57.39 @ Amazon Deutschland)
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (€47.72 @ Amazon Deutschland)
Video Card: Gigabyte Radeon RX 570 4GB Gaming 4G  Video Card  (€207.35 @ Mindfactory)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  (€55.01 @ Mindfactory)
Total: €580.24
Generated by PCPartPicker 2017-04-28 16:20 CEST+0200
1 hour ago, Jubsi said:
Hello everyone
Crucial has ssd's for roughly $20 cheaper at each price point. And they perform just as well. Also, you could get a bronze non modular psu for $15 less. A cryorig H7 isn't a bad option for the price if your looking to save money on the gpu cooler.
2 hours ago, Jubsi said:
Ok I switched out the CPU for an Penium g4560 and the mainboard for one with a B250 Chipset which brings the total cost (including Case and CPU Cooler) down to 540€ which is good since cheaper is in this case better ^^
Don't get an aftermarket cpu cooler of you are going with the Pentium. That money would be better spent elsewhere. The cpu that comes with the Pentium is good enough as you can't overclock so you don't need the extra thermal headroom.
