need some help with ram.
Go to solution Solved by Mira Yurizaki,
Higher speed RAM probably wouldn't hurt, but you also probably won't notice a difference.
Also how much money are you willing to spend?
so i will be getting AMD Athlon X4 870K latter this year and a Asus A88XM-A/USB 3.1 motherboard and i will use a gtx 1050 gpu. i was thinking to get Kingston DDR3L 4GB 1600MHz Non-ECC CL11 DIMM 1.35V ram. Will this ram be good or should i get a higher clocked? i have i3 550 and asus p7h55 motherboard and 2x2 1600 ram. i want to get ram first motherboard and cpu second so that when i get the cpu and mobo i could use my egzisting ram. i plan on getting full 16gigs of ram on all 4 slots.
Some people told me to wait for ryzen 3 and get that but i saw that it will need high speed ddr4 ram and a more expensive mobo wich will be to expensive for me so this idea is out of the window.
mabie anyone has any other sugestions for ram, cpu or mobo?
https://linustechtips.com/topic/772316-need-some-help-with-ram/
5 minutes ago, Volde said:
on ram i will spend 100 on full kit
Yeah, $100 for a complete system feels out of the question. At best, you just open up an upgrade path by going to a cheapo Intel system with maybe 8GB of RAM, but who knows how long that'll take to get said upgrade?
https://linustechtips.com/topic/772316-need-some-help-with-ram/#findComment-9746386
