I have only the motherboard, RAM, PSU, and CPU connected.
An ASUS Z270E motherboard, two 8 gig sticks of G.Skill Trident Z RGB RAM (3000), Core i7 7700K, and a Rosewill 550W Photon PSU.  I can't get it to post.
 I checked with the motherboard manual and the two RAM sticks are in the appropriate DIM slots, but the RGB is not lighting up.
The Motherboard power LED is on as well as the on board RGB.
Any idea what the issue might be?
Thank you
Will
https://linustechtips.com/topic/771989-diy-build-is-not-posting/
3 hours ago, zMeul said:
you put that much muney in the system and bought that shit PSU?! mate ...
you seem to be lacking a CPU fan, mobos are most likely not to boot without it
It makes me worried that there isn't a CPU heatsink in that photo. >.>
https://linustechtips.com/topic/771989-diy-build-is-not-posting/#findComment-9742126
5 minutes ago, zMeul said:
it doesn't really matter, CPUs nowadays have serious protection and will throttle instantly
though maybe asus implemented that there needs to be a cpu fan connected.
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/771989-diy-build-is-not-posting/#findComment-9742188
I wanted to use minimum components to post just to make sure that they work.  I don't think the system would be able to detect a heatsink even if there was one.  I do plan on getting a good cpu cooler though.
you seem to be lacking a CPU fan, mobos are most likely not to boot/POST without it
This isn't a bad power supply.  Since Linus primarily uses power supplies from sponsors, you probably haven't heard much about Rosewill power supplies.  It is highly rated, certified 80+ gold efficiency, and uses all Japanese capacitors.
https://linustechtips.com/topic/771989-diy-build-is-not-posting/#findComment-9745174
LOL
Wtf. You need a cpu cooler. It's a i7 not a i486.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/771989-diy-build-is-not-posting/#findComment-9745197
Use the stock one?
https://linustechtips.com/topic/771989-diy-build-is-not-posting/#findComment-9745208
4 minutes ago, Spenser1337 said:
Use the stock one?
7700k doesn't come with a stock cooler. Intel presume you have a brain if you buy a 7700k :P
Rig Specs:
https://linustechtips.com/topic/771989-diy-build-is-not-posting/#findComment-9745221
I doubt they presume you have a brain they're probably just being cheap
at least with ryzen you get a competent stock cooler
https://linustechtips.com/topic/771989-diy-build-is-not-posting/#findComment-9745248
Rosewill is a offbrand of NewEgg - it's not a recognised nor respected PSU manufacturer
Jap capacitors nor gold cert matter if/when the platform the PSU is built on is shit
https://linustechtips.com/topic/771989-diy-build-is-not-posting/#findComment-9745406
Unless you get the 1700x 1800x or 1600x :P
Rig Specs:
https://linustechtips.com/topic/771989-diy-build-is-not-posting/#findComment-9745412
aren't you funny ...
a CPU cooler that can withstand overclocking of a K series CPU can go north of 50$ - you'd be screaming and kicking if Intel would've asked 50$ on top of the CPU
https://linustechtips.com/topic/771989-diy-build-is-not-posting/#findComment-9745441
Isn't the 212 25$?
i also hope you understand it costs intel pennies to manufacture a cooler.
https://linustechtips.com/topic/771989-diy-build-is-not-posting/#findComment-9745521
I would take you a little more seriously if you would give solid reasons why this Rosewill power supply is bad.  All you have said is that it is sh!t.  I doubt you have even tried it for yourself.
https://linustechtips.com/topic/771989-diy-build-is-not-posting/#findComment-9755565
I can't try one myself as those do not reach Europe
but, there are reviews around
https://linustechtips.com/topic/771989-diy-build-is-not-posting/#findComment-9755573
