CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($89.70 @ PB Technologies) ask seller if bios supports kabylake cpus.
Motherboard: Gigabyte GA-H110M-S2H Micro ATX LGA1151 Motherboard  ($100.80 @ PC Force)
Memory: Kingston ValueRAM 8GB (1 x 8GB) DDR4-2133 Memory  ($85.44 @ PC Force)
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($74.50 @ 1stWave Technologies)
Video Card: Sapphire Radeon RX 480 8GB Video Card  ($339.25 @ PB Technologies) rx 470 If you can't spend extra.
Case: Deepcool SMARTER MicroATX Mini Tower Case  ($52.00 @ PB Technologies)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($95.00 @ 1stWave Technologies)
Total: $836.69
Generated by PCPartPicker 2017-04-26 15:36 NZST+1200
Total: $836.69
So, is there a video where it shows how to do the "BIOS update prior to using Kaby Lake-S CPUs" thing?
if you want to update it yourself you'll need any skylake CPU to do it. you should be able to contact the store or seller, see if you can find out from them if the kabylake supported bios is already pre-installed.
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($87.40 @ PB Technologies)
Motherboard: Asus PRIME B250M-K Micro ATX LGA1151 Motherboard  ($120.74 @ PB Technologies)
Memory: Kingston ValueRAM 8GB (1 x 8GB) DDR4-2133 Memory  ($85.10 @ PB Technologies)
Video Card: Gigabyte GeForce GTX 1060 3GB 3GB Mini ITX OC Video Card  ($306.24 @ PC Force)
Case: Cooler Master MasterBox Lite 3 (Windowless) MicroATX Mini Tower Case  ($52.71 @ PB Technologies)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($68.99 @ PB Technologies)
Total: $795.68
Generated by PCPartPicker 2017-04-28 12:34 NZST+1200
