Hey Guys
hopefully this is a quick question for you.
Im running an i7-7700k on my new build with an NZXT x52 AIO for cooling, but when i run cpu-z stress test the NZXT CAM software is recording cpu temperatures on 88+ this seems insane to me.
Is this normal? i know 100% load for an extented period of time isn't exactly the norm but based on various videos on youtube etc nobody else seems to ever record anything over 78ish.
advice if needed would be greatly received
https://linustechtips.com/topic/771107-stress-test-temps/
18 minutes ago, RedShift7 said:
Hey Guys
Check the mounting of the cold plate.
Use Real Bench to stress test, or AIDA64.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/771107-stress-test-temps/#findComment-9731815
16 minutes ago, Colin Donoghue said:
Processor Number:   I7-7700K
  Thermal Design Power:   91 W
  Thermal Specification:   100 °C
  Type:   Core i7
https://www.cdw.com/shop/products/Intel-Core-i7-7700K-4.2-GHz-processor/4435615.aspx
does this mean anything below 100 is fine? that seems really hot
ill try real bench now, i did think the connection to the cpu could be bad. i didnt add any thermal paste to the AIO when i got it as it already had some on. altho it seemed a puny amount.
https://linustechtips.com/topic/771107-stress-test-temps/#findComment-9731865
15 minutes ago, Daniel644 said:
what are your voltages like? I know on my 6700k my voltages where going MUCH higher at stock settings then I ended up at after overclocking.
Just done the real bench stress test, during the encoding the cpu got to 92 degrees. The voltage while running the test was 1.232v according to cpu-z.
could air flow be an issue? my rad is in a front mounted pull config, and the case fans are both 120mm top and rear exhausts
https://linustechtips.com/topic/771107-stress-test-temps/#findComment-9731962
4 minutes ago, RedShift7 said:
seems like the best place to start. thanks for your help
also when reinstalling remember the basics like don't lift the cooler back off the CPU after setting it down with the new paste and tighten the 4 mounting points in the order they say to in the manual.
https://linustechtips.com/topic/771107-stress-test-temps/#findComment-9732016
totally agree, that thing is not making good contact. or the pump isn't working.
System specs:
https://linustechtips.com/topic/771107-stress-test-temps/#findComment-9732280
On 24/04/2017 at 9:32 PM, Colin Donoghue said:
get some good thermal compound an that should help a lot
Just changed these thermal compound and re run real bench and prime95 and temperatures have dropped from 90 odd to just over 70.
Thanks so much ?
https://linustechtips.com/topic/771107-stress-test-temps/#findComment-9750527
Thanks so much ?
You are lucky that you don't need to delid it to drop in temp.
I'm glad it's fixed for you :)
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/771107-stress-test-temps/#findComment-9751239
