[HELP] pc won't post.
Solved by FrostieCooky,
5 minutes ago, ZM Fong said:Try remove the GPU and plug monitor cable to mobo.
If not, it could be CPU/mobo/RAM problem.You can replace them by buying a new one?
The first picture shows covers over the screws. The gpu cannot be removed thus the mobo cannot be removed and neither be replaced.
_Darasuum_ ·
Posted in Power Supplies2 -
anothertealtiger ·
Posted in Programs, Apps and Websites2 -
Mumintroll ·
Posted in Programs, Apps and Websites4 -
ElDTac ·
HunterSVK ·
Posted in Troubleshooting4 -
Ozzi ·
Posted in Networking5 -
2
MadManMarsBar ·
Posted in Build Logs3
play_circle_filled
Latest From ShortCircuit:
