Need help with this 2 keyboards.
Solved by 19_blackie_73,
The g610 is a solid choice, only thing thats a bit odd is that you have to set the lighting every time after startup to constant on (default is wave) or install the software
CM is cool to, though i dont see the benefit of spending 30 bucks extra
Featured Topics
Bobzcpu ·
Posted in Power Supplies2 -
1
RZBAKA ·
Posted in New Builds and Planning6 -
1
Magnumenforce ·
Posted in Phones and Tablets2 -
1
Crash The Noise ·
Posted in Programs, Apps and Websites3
