9 minutes ago, LiamGrahamCracker said:
hi guys,
My computer boots normally and there doesn't seem to be any problems with it but after I've been using it for about 45 minutes it starts making this annoying clicking noise and I think its coming from my CPU fan, anyone experience similar problems?
It sounds like the fan bearing or such may be worn out or at a certain speed where it starts to tick. You might be able to add some oil to the bearing or need to replace the fan.
https://linustechtips.com/topic/770776-computer-noise/#findComment-9728031
