Iv just been through all the Wireless ac speed cards on pbtech and none of them appear to have linux drivers included in the kernel. I want to avoid proprietary drivers. Is there a wireless, ac , PCIe card with opensource drivers in NZ or able to be shipped from overseas at under $60NZD - I can pay more but for international orders it needs to be under the tax limit or it gets stupidly expensive with all the duty charges they slap on.
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/770738-wireless-ac-pcie/
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/770738-wireless-ac-pcie/#findComment-9727686
8 minutes ago, tmcclelland455 said:
that uses  Intel 8265 which has limited features in linux, a few bugs, and does not use drivers included in the kernel
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/770738-wireless-ac-pcie/#findComment-9727724
What OS? Do they have a list of approved wireless chips?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/770738-wireless-ac-pcie/#findComment-9727741
Beggars can't be choosers...
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/770738-wireless-ac-pcie/#findComment-9727844
linux any kernel from 4.4
each chipset will have a page on the debian or archwiki. The trouble is going to each card finding which chip it uses.
im not begging. I have quite a specific question thank you.
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/770738-wireless-ac-pcie/#findComment-9727863
It's an expression, mate. Ubuntu is a pain in the ass to get 100% guaranteed compatibility with. I used the last-gen version of the same card (only difference is Bluetooth 4.0 vs 4.2 I believe), and it worked flawlessly.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/770738-wireless-ac-pcie/#findComment-9728278
1 hour ago, GreenZombie said:
This works and the price is reasonable.
https://www.asus.com/Networking/PCE-AC51/specifications/
debian wiki says i need to use the non-free firmware and im trying to avoid this. Im use to using the ath9k driver and im trying to update to ac speed. I dont want closed drivers because i dont want my NIC to get knocked out from an update.
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/770738-wireless-ac-pcie/#findComment-9729203
Just now, GreenZombie said:
Linux Mint 18.1 (kernel 4.10.0-19) does not have any problems with the Asus PCE-AC51 wlan card. The card was already in use with a couple of kernel updates.
Once again NO PROBLEMS !!!
Doesnt Mint have closed source repos enabled by default? Im looking for a card that has drivers in the kernel. i.e. works with a proper server OS without enabling drivers that have potential to break operation like the ath9k that I am use to using. I just don't see that in the debian or arch wikis. That is the point of my post that I seem to have failed to communicate.
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/770738-wireless-ac-pcie/#findComment-9729459
You won't know until you try the product, to be honest. Make a full backup of the OS before you try the product. If everything runs well, you're in the clear. If not, just revert and return the card.
https://linustechtips.com/topic/770738-wireless-ac-pcie/#findComment-9730092
It seems quite a lot of devices use proprietary firmware. Seems this is a good summary (not sure how much of this is up-to-date/out-of-date): https://en.wikipedia.org/wiki/Comparison_of_open-source_wireless_drivers
However, I wouldn't worry about using proprietary firmware too much - unless you have an ideological reason to use more open hardware. Generally the drivers with closed firmware work quite well. But avoid those which do not have a driver in Mainline kernel at all!
https://linustechtips.com/topic/770738-wireless-ac-pcie/#findComment-9730542
I have been using that chart. What iv done is quite laborious. I go to pbtech.co.nz which is a site that reflects what is available in NZ, then i go to the OEM website, download the driver to see what it uses, then go to wikipedia and debian wiki to see if its in the kernel. I just cant find anything ac speed.
I dont want proprietary because drivers in the kernel are so much easier, I can install any linux and it will work, i think its quite important for NICs because its a bit of a catch 22 needing the internet to get a NIC working. I have had laptops in the past that use proprietary broadcom and it just takes up time getting it working.
Iv been using the ath9k chipset for a while, its fully featured so im looking for something equivalent in PCIe and ac speed. I should prob go ask on the level1 forum.
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/770738-wireless-ac-pcie/#findComment-9732484
Ok, now I understand why you need a really open driver.
It may be possible some other forum with more similar user base may be more helpful.
(EDIT: now that I re-read your comment, I still think you may be confusing closed-firmware open-source driver with closed-source only driver. The latter can be a PITA to install, the former should "just work" as long as the firmware is downloaded, which usually exists on most Linux installation medias, and as such does not need to be download - and if it does not exist on the media, only a single binary blob is usually required to be copied somehow off-line. Drivers needing proprietary firmware drivers which are in the mainline Kernel equals downloading the firmware, usually into /usr/lib/firmware, which can be done trough most distributions package manager. After this the driver will work as any open-source driver from users perspective; i.e. there should be no reason it would break at a kernel upgrade etc. Downloading the firmware may be a bit more license-encumbering, however (i.e. not strictly GPL/FOSS).
https://linustechtips.com/topic/770738-wireless-ac-pcie/#findComment-9735393
