Hi Guys, I need help building my first pc.. I have a few questions and would appreciate any input!
I'm on a bit of a budget and to accommodate the graphics card I had to cut corners elsewhere.
Please go easy on me :D
Okay so the build is;
Phanteks P400s TG Case
Ryzen 5 1500x
MSI B350 Mortar AMD AM4 Motherboard
Sapphire Pulse Radeon RX 580 8GB
Ballistix Sport LT - 8GB DDR4 Ram (288 pin)
WD 1TB Blue
EVGA 500w 80+ B Power Supply.
So my first question is i can either have an SSD or a 1TB hard drive.. if I bought a 250GB SSD can I build it with only the SSD (temporarily for 2 months until I buy bigger SSD or Hard drive).
I just mainly want to know if all the parts are applicable.
The main use atm is for gaming and programming/coding.
Thanks!
https://linustechtips.com/topic/770694-computer-noob-need-help-with-first-build/
grab a ssd now and then grab the hard drive after. make sure to get fast ram for ryzen 2666 or 2800 are good speeds. grab a different psu something from tier 1 or 2 from the PSU tier list (can be found in my sig or under power supplies)
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Don't worry so much about RAM on a budget.  Get a 1600 rather that a 1500x as for an extra $30 you get 2 more cores and thus much more longevity
Want to custom loop?  Ask me more if you are curious
Ryzen 5 1500x
WD 1TB Blue
Thanks!
i would upgrade to 16gb of RAM.  get an ssd and then a HDD later
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
Definitely get SSD first, much easier.
Don't get an R5 1500x, get either a 1400 or a 1600. I'd make sure to get at least 2666Hz RAM with Ryzen. Aim for 2800MHz+ though. From what I've seen, 3000/3200MHz is the best price/performance for RAM with Ryzen. Obviously if the price difference between 2666/2800MHz and 3000/3200MHz is significant wherever you're buying, get whichever is significantly cheaper.
Maybe don't spend so much on the case, that could let you get an HDD and SSD and/or the 1600 over the 1400/1500x and/or a better PSU. I definitely would not recommend using that PSU, it's a fairly low quality, budget unit.
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
