Hey guy's
Sorry if this is in the wrong place but I figured that this does have to do with power in a PC, and I want to put this all in a custom built case so I thought that was fitting.
So I was wondering, is it possible to run a PC off some sort of battery... It's definitely possible because laptops are a thing but I want to be different, I wonna be the idiot that has a custom built PC running off a battery, so I can run Microsoft Exel at 60fps on the go.
Here are the spec's that I will probably have (Need a Job)
- Low end Ryzen5 or high end Ryzen3
- some ITX motherboard meme
- Gtx 1050ti
- 120gb-240gb SSD 1tb HHD
- 8gb of some dank AF ram
- EVGA 500watt PSU 80plus bronze I think
So my idea included having a DC to AC converter from battery to PSU and the PSU would run the PC just like normal, but would that work and if not, what would?
Is this retarded, actually don't answer that I already know it is. But can it be done, and if so, how can it be done?
Thanks for the help
ya boi Zucchini
https://linustechtips.com/topic/770185-running-pc-off-a-battery/
it'll work, but  like.. no..
highly inefficient (DC -> AC -> DC)
very very heavy
30m runtime
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/770185-running-pc-off-a-battery/#findComment-9722090
You may be able to get something that works, but the battery won't last for very long.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/770185-running-pc-off-a-battery/#findComment-9722094
Just now, RGProductions said:
Everybody, this is possible
You just need to eliminate the PSU and get something like a picopsu, except more robust. Which probably doesn't exist.
It's not impossible, just EXTREMELY impractical.
Main System: Phobos
https://linustechtips.com/topic/770185-running-pc-off-a-battery/#findComment-9722108
you might want a gt 710 lets say, as it's a 19W compared to the 1050ti 75W, making it alot better as it's good enough for excel
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
https://linustechtips.com/topic/770185-running-pc-off-a-battery/#findComment-9722120
Gt 710's are so lit, they don't come with a fan.
"runs up to 1.5x faster than an IGPU" from the Nvidia
Microsoft Exel 60fps, but can it run roblox?
https://linustechtips.com/topic/770185-running-pc-off-a-battery/#findComment-9722162
probably can, and the low TDP will help a lot running off a battery as that 56W will be massive as it depending on the battery you use, could add upto an extra hour onto the battery life, as it will be drawing 56j of energy per second less with the gt 710, and I agree it anit the nicest looking, but an igpu can run roblox so you know,. should be fine
https://linustechtips.com/topic/770185-running-pc-off-a-battery/#findComment-9722186
Just now, emmettontheweb said:
So I was on amazon and I found this thing called a Laptop and they have a battery built in so I would recommend that. Here's one: LOL
that is also true, and it's probably/definitely easier to do that. that being said I recon it could be cool to make your own laptop, and from what I remember from when I looked into to it, it wasn't impossible, just expensive as you needed to get the case specially made, as well as a screen to run it off. And I have no idea what thermals would be like
https://linustechtips.com/topic/770185-running-pc-off-a-battery/#findComment-9722223
good point just want a PC that looked like this...
https://linustechtips.com/topic/770185-running-pc-off-a-battery/#findComment-9722258
nah, that looks far to good for what I'd make :P
https://linustechtips.com/topic/770185-running-pc-off-a-battery/#findComment-9722265
Perhaps incorporate a UPS into the build? Would probably mean a custom case.
As others have said...ridiculously impractical and the battery won't last long.
DAEDALUS (2018 Refit) - Processor: AMD Ryzen 5 - 1600 @ 3.7Ghz // Cooler: Cooler Master Hyper 212 LED Turbo Black Edition // Motherboard: Asus RoG Strix B350-F Gaming // Graphics Card: Gigabyte GTX 1060 Windforce 6GB GDDR5 // Memory: 2 x 8GB DDR4 Corsair LPX Vengeance 3000Mhz // Storage: WD Green - 250GB M.2 SATA SSD (Boot Drive and Programs), SanDisk Ultra II 120GB (GTA V), WD Elements 1TB External Drive (Steam Library) // Power Supply: Cooler Master Silent Pro 700W // Case: BeQuiet Silentbase 600 with SilentWings Mk.2 Internal Fans // Peripherals: VicTop Mechanical Gaming Keyboard & VicTsing 7200 DPI Wired Gaming Mouse
PROMETHEUS (2018 Refit) - Processor: Intel Core i5-3470 @ 3.2Ghz // Cooler: Cooler Master 212 EVO // Motherboard: Foxconn 2ABF // Graphics Card: ATI Radeon HD 5450 (For Diagnostic Testing Only) // Memory: 2 x 4GB DDR3 Mushkin Memory // Storage: 10TB of Various Storage Drives // Power Supply: Corsair 600W // Case: Bitfenix Nova Midi Tower - Black
SpeedTest Results - Having Trouble Finding a Decent PSU? - Check the PSU Tier List!
https://linustechtips.com/topic/770185-running-pc-off-a-battery/#findComment-9722294
custom case, and if you use pico power supplies, some can run off outputs from some battery packs (the ones that output only a 12V power supply) meaning you can you can use them instead of a big UPS
https://linustechtips.com/topic/770185-running-pc-off-a-battery/#findComment-9722312
