Hey all,
I recently got back into CSGO and noticed that i'm getting unusually low FPS -- between 150 and 200.  I can understand being CPU limited, but I used to max out at 300fps when I had my AMD 7950.  Surely, with the 1080 and the same CPU, I should get at least as much FPS.  I tried at both 1080p and 1440p with no difference.
Are there any tweaks I should look at, or is this due to a game update?  I already set Max FPS to 0 in order to remove the FPS cap...
Thanks.
CPU -AMD R5 2600X @ 4.15 GHz / RAM - 2x8Gb GSkill Ripjaws 3000 MHz/ MB- Asus Crosshair VII Hero X470/  GPU- MSI Gaming X GTX 1080/ CPU Cooler - Be Quiet! Dark Rock 3/ PSU - Seasonic G-series 550W/ Case - NZXT H440 (Black/Red)/ SSD - Crucial MX300 500GB/ Storage - WD Caviar Blue 1TB/ Keyboard - Corsair Vengeance K70 w/ Red switches/ Mouse - Logitech g900/ Display - 27" Benq GW2765 1440p display/ Audio - Sennheiser HD 558 and Logitech z323 speakers
https://linustechtips.com/topic/768306-low-fps-in-csgo/
remove (using DDU) and reinstall the latest available drivers for your GPU.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/768306-low-fps-in-csgo/#findComment-9699663
I've tried that :(
https://linustechtips.com/topic/768306-low-fps-in-csgo/#findComment-9699670
Uninstall the game and delete every file and folder associated with it.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/768306-low-fps-in-csgo/#findComment-9699675
OK, I'll give that a shot
https://linustechtips.com/topic/768306-low-fps-in-csgo/#findComment-9699681
Didn't make a difference :(
https://linustechtips.com/topic/768306-low-fps-in-csgo/#findComment-9699879
This doesn't help, but I too have seen issues with CSGO and frame rates.
Do you happen to know if your CPU is being fully utilized? If you can check that maybe it might point us in a direction.
My own personal experience with this lately:
I was getting large fluctuations in fps 110-180 with about 75% at most on any core. Then suddenly last week it was 230-288 and now I am back to 110-180. I never found out the reason for the change up or down.
https://linustechtips.com/topic/768306-low-fps-in-csgo/#findComment-9702295
Lately, CPU usage hovers around 65-75% and GPU around 55-65%.  I just reinstalled windows and am in the process of setting up all my games.  I'll report back with results once CSGO is up and running.
https://linustechtips.com/topic/768306-low-fps-in-csgo/#findComment-9702472
