I was using my PC normally when suddenly the display froze. Rebooting didn't work (no screen signal), but all the fans turned and the graphics card (gtx 1060) lighted up. My mouse light did turn on which meant the problem was my graphics card. I tried plugging the hdmin onto the onboard graphics and it booted up. So I opened up the pc, removed and reput the graphics card and tried booting it up from the gfx card input. Didn't boot up, mouse didn't light up. I plugged it into the onboard graphics and it still didn't boot up.
Any help would be greatly appreciated :)
https://linustechtips.com/topic/767744-need-help/
sounds like your GPU took a shit. RMA it.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/767744-need-help/#findComment-9693667
Just now, iMix- said:
But.. Not even the onboard graphics are working
sounds like it was working to me... But if you're NOW saying that the iGPU isn't working either, it could be because there is a GPU installed. Generally speaking, if the MB detects a GPU installed in the PCIe bus, it disables the iGPU. You have to remove the GPU for it to switch back.
System specs:
https://linustechtips.com/topic/767744-need-help/#findComment-9693725
Edit: Never mind @knightslugger had posted the same thing
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/767744-need-help/#findComment-9693728
Nope, removed it and still doesn't boot up with internal graphics.
https://linustechtips.com/topic/767744-need-help/#findComment-9693748
Didn't work. I think I gave up, this thing isn't going to work.
Did you try my suggestion of removing *AND LEAVE REMOVED* the GPU? The iGPU will not function with a GPU in the PCIe bus by default.
NM, i see you did.
System specs:
https://linustechtips.com/topic/767744-need-help/#findComment-9693861
1 minute ago, HolaImBob said:
if you got another pc available try test the gpu, ram and cpu (if socket is the same) in that pc, if not id just rma all the parts separately or if the pc is branded like dell or cyberpower contact their support.
The problem is with the motherboard I think. Did some testing, the frontal USB ports (the ones in the case) work, the ones from the I/O thing don't. Any ideas?
https://linustechtips.com/topic/767744-need-help/#findComment-9693921
28 minutes ago, HolaImBob said:
have you checked all of the connections from the psu to the mobo and graphics card. i have no clue what the problem would be, just try everything you can without voiding warranties.
I fixed it! I disconnected and reconnected the EATX 12V power cable and it booted up perfectly fine. I figured it might have not been supplying energy to the I/O thingy and the motherboard itself, so I decided to try doing that. Thanks a lot for the help!
https://linustechtips.com/topic/767744-need-help/#findComment-9694069
