Rome II: Total War Issues
Go to solution Solved by Guest,
I wipe and reload my operating system annually, and it was around that time anyway so after a fresh install of Windows the game launches no problem. I have no idea what the issue was but it's at least resolved.
I wasn't sure if this post belonged in the Troubleshooting area or the PC Gaming area, so mods please forgive me if this is in the wrong place. I've owned the game Rome II: Total War for quite some time now, and enjoyed it much on Windows 10 several months ago. Since uninstalling it I felt like getting back into it, so I re-downloaded it and attempted to launch it just like all my other Steam games. Except it doesn't launch - it says 'Running' next to the title then quickly flashes into 'Syncing' and then goes blank. Nothing happens. Task manager doesn't report it starting and there isn't the usual Launcher that shows up where you can check/uncheck your mods. It just sits there. I've scoured the Internet but most posts I can find are from 2014 and 2015, and all are listing similar 'fixes'. Here's an abbreviated list of what I've done.
- Restarted
- Verified integrity (cache) of game
- Uninstalled/reinstalled
- Used CCleaner to clear registry after uninstall
- Attempted launch from within the directory
- Logged out/into Steam
- Deleted appdata
- Unsubscribed from mods
I've probably done various other things as well, but most of the online help discussed these topics. The only thing that's changed is I recently updated to Microsoft's little Creator update deal, though I can't understand how that would affect this game. All my other Steam games work just fine. I included a short video of what this game does when I try to launch it (it's being run as an admin and is after a fresh install).
I'm truly out of ideas. Anyone had this issue with another game or this one specifically? Thanks for any help!
https://linustechtips.com/topic/767414-rome-ii-total-war-issues/
Ahhh Rome II! so many memories...
But yeah buggy as hell,,,,, I think i had a similar problem with it at one point, never found a solution it just "fixed" itself.
Maybe try reinstall drivers? since its the only one you havent tried yet...
Bleigh!  Ever hear of AC series?
https://linustechtips.com/topic/767414-rome-ii-total-war-issues/#findComment-9690372
If you're referring to video card drivers, I just did it again just to be safe. Still fails. Thanks for the reply though
https://linustechtips.com/topic/767414-rome-ii-total-war-issues/#findComment-9690412
Ctrl+Alt+Esc.
Find the application.
End task.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/767414-rome-ii-total-war-issues/#findComment-9690494
5 minutes ago, ARikozuM said:
Ctrl+Alt+Esc.
End task.
This might work!! Good idea man.
I rmemeve the launcher getting blocked in the background and giving a similar error. It wouldn't run correctly (it also sometimes doesn't quit properly). So yeah when you do this, make sure to check if there's several things total war open.
https://linustechtips.com/topic/767414-rome-ii-total-war-issues/#findComment-9690532
On 4/16/2017 at 4:35 PM, ARikozuM said:
Ctrl+Alt+Esc.
End task.
That's my whole issue though, the application never gets started. Nothing relating to Rome ever gets off the ground, so there's nothing to end. That's what's so strange about all this.
https://linustechtips.com/topic/767414-rome-ii-total-war-issues/#findComment-9695948
  • 3 weeks later...
Did UAC or Windows Defender block the program?
Glad to hear you resolved it.
https://linustechtips.com/topic/767414-rome-ii-total-war-issues/#findComment-9806244
Nope, nothing blocked it because it didn't even start. Task manager saw it for a fleeting moment but it didn't even last three seconds. Kinda sucks that it took an entire reload but I was going to do it anyway.
https://linustechtips.com/topic/767414-rome-ii-total-war-issues/#findComment-9808747
