Which cable goes into ATX2V1?
IAR117
I think that's what it's called, it goes at the top, just above the CPU
The 8-pin? There's only one that fits in it. It's either 8-pin or two 4-pins side by side.
Edit: Depending on what processor you have, you may be able to get by by just plugging one 4-pin in it. In that situation it goes on the right if the clip is on top. If you do have two 4-pins, plug both in because you can never really be sure if just one is enough to keep it stable.
CPU 1? I7 4790, so prob not on 4 pins. With my cables, for CPU 1 which are 2x 4PINs, it's incredibly fiddly to install. What an I doing wrong?
Yeah, you'll need them both. Since it's a modular PSU, I'd plug the cables in the mobo first and then route it to the PSU. In my mind there's not much to it. Hold the two 4-pins side by side with the clips together in the middle and push them in together. The plastic part is beveled in the corners so you can't (not a challenge, with force you can) plug a wrong cable in the wrong spot. Which reminds me, did it come with a second CPU cable with a straight up 8-pin? You can use that too.
I'll check when I get home, I'm out right now. I guess you can check on EVGA's website of you want
You're talking about the EPS connector. You can usually plug one in of the 4-pin and then follow with the 2nd 4-pin.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Can I use CPU 2? Is that the single 8 pin u guys were talking bout?
Yes. If it fits in it's fine.
