So while moving my computer i bundled in both my monitor cable and psu cable into to same bag, they appear to be similar cables but i was wondering if it makes a difference if i accidentally plug the wrong one into my PSU, it's a cosair CX750. one of the fuses says 13A and the other says 5A if that helps
https://linustechtips.com/topic/766852-psu-cable-help/
If your in the UK and such and have fuses in the plug use the larger fuse on the PSU, as the monitor is very low power draw by comparison.
https://linustechtips.com/topic/766852-psu-cable-help/#findComment-9684046
