Hey all, I have a laptop I use (Which I currently am using) To play games, discord (not at same time now because i simply cant) It is pretty old but It's been running fine.
But now Whenever I play a game or use Chrome,Steam and discord (open at once since I talk to people) The battery goes from plugged in, to charging (on battery) back and forth back and forth. And then sooner or later it makes me crash... It's really annoying since I'm trying to play games (Like Garry's mod which usually runs fine, with like over 55fps)
My laptop model is Asus N61JQ. any help is appreciated :)
Ryzen 5 3600
RX 590 8GB
WD Blue 1TB
(full specs on profile)
https://linustechtips.com/topic/766268-need-laptop-help/
Remove the battery when playing? Can you use a different outlet or charger to see if those could cause the issue?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/766268-need-laptop-help/#findComment-9677611
I don't have another charger, And I will try use a different outlet (on the wall right?) And what do you mean by Remove the battery?
Ryzen 5 3600
RX 590 8GB
WD Blue 1TB
https://linustechtips.com/topic/766268-need-laptop-help/#findComment-9677623
Check if the wall outlet could be the issue (doubt it) and can you physically remove the battery when you're trying to multi-task?
https://linustechtips.com/topic/766268-need-laptop-help/#findComment-9677632
It's a laptop, I can't remove the battery whilst on.. lol It'll turn off the whole system. And I'll try a diff outlet
Ryzen 5 3600
RX 590 8GB
WD Blue 1TB
https://linustechtips.com/topic/766268-need-laptop-help/#findComment-9677638
Wall outlet isn't the cause.
Ryzen 5 3600
RX 590 8GB
WD Blue 1TB
https://linustechtips.com/topic/766268-need-laptop-help/#findComment-9677641
Most laptop still functions with battery removed while the power plugged in. Which laptop btw? If different outlet doesn't work then bye bye battery
https://linustechtips.com/topic/766268-need-laptop-help/#findComment-9677643
Blind. I said it's a Asus N61JQ in OP
Ryzen 5 3600
RX 590 8GB
WD Blue 1TB
https://linustechtips.com/topic/766268-need-laptop-help/#findComment-9677648
Which laptop btw?
I have two "really!?"s for you.
1st. Your icon.
2nd. Quote.
https://linustechtips.com/topic/766268-need-laptop-help/#findComment-9677653
6 minutes ago, Rika Shiguma said:
I'm gonna pastebin Here: https://pastebin.com/gPgEPcAH
Design Capacity 48400
Last Full Charge    24200
So the battery has worn out by half
You sure it doesn't work while plugging and with battery removed? That's really really really really really really odd, even my old HP G50 with Win Vista can
https://linustechtips.com/topic/766268-need-laptop-help/#findComment-9677730
Idk if it works.
Ryzen 5 3600
RX 590 8GB
WD Blue 1TB
https://linustechtips.com/topic/766268-need-laptop-help/#findComment-9677736
try...
WAIT. this is a different battery that did not come with the laptop since the last one like, fucked up or smthn (idk what the reason was i forgot when we changed it) and so is the charger.
Ryzen 5 3600
RX 590 8GB
WD Blue 1TB
https://linustechtips.com/topic/766268-need-laptop-help/#findComment-9677745
