Hi.
Sorry if i broke some rules posting a request like this, this is my first time posting in these forums and i dont know where else to go, nobody seems to understand my problem.
My gpu fan will oscillate.  No, it is not coil whine, after doing some testing I am almost 100% sure it is the fan.  It sounds like a "woo woo woo"  (please dont laugh im dead serious) and it is very high pitched so it cuts right through my headset and makes it next to impossible to concentrate when playing any games.
The only temporary solution i found is to manually set the fan speed to a fixed speed, like 40%.  Fan curves do not help, only a consistent speed.
The card is brand new, 2 months old and has never been overclocked.  I don't think i can return it since I ordered this online and quite frankly i dont want to go through the trouble of returning it.
Any possible solutions are greatly appreciated.  Card is Evga 1060 and drivers are updated.  From the looks of it, It seems like this is the standard card and not some fancy model.  I would hope to run games without having to go into m si afterburner and set the fan speed up every time I play something.
Thank you for reading
https://linustechtips.com/topic/766205-gpu-fan-oscillating-please-help/
Maybe there's an imperfection on the fan blade? Like a piece left over from molding?
I don't know if the EVGA cards have 'hot swappable' fans, but it's worth taking a look.
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
But thats the thing.  There does not appear to be anything inherently wrong with the card. Temps are fine, fans look and spin fine, nothing appears off in the construction of the card.
Did i just get super unlucky and got the worlds first undiagnosable gpu?  Lmao
well, if there's nothing on the fan props that could  cause vibrations, it can only be the bearing. You got unlucky and got a bad bearing in one of your fans. Maybe replace the cooler with an arctic accelero or something?
