My computer recently for around 1-2 minutes made a weird noise. It was pretty much a very low-volume electrical humming sound. I saw that it could be something with the power supply (Hey, I've got a power supply that's pretty bad. It runs fine tho). What is it?
Specs:
CPU: i3 4160 (Haswell, LGA 1150) with stock cooler.
RAM: Single-Channel 8GB RAM (1x8GB) at 1596MHz from Kingston
Motherboard: Gigabyte H81M-S1 rev2.1 (Haswell, LGA1150)
Monitor: Flatron L192WS
GPU: Nvidia GTX 950, model made by GIGABYTE
HDD: 931 GiB/0.909TiB/1000GB/1TB Western Digital WDC WD10EAVS-00D7B1. Uses SATA.
SSD: None
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/765944-weird-noise-from-computer/
Try to unplug all fans except the critical ones and turn the system on.
Dying fans can make all kinds of noises too.
Alternatively, stop the fans one by one by holding the blades. I don't recommend this method though, it's not good for the fans to be held still.
Its more than likely coil whine; not much you can do about it. What PSU do you have?
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
19 minutes ago, NunoLava1998 said:
It sounds nothing like coil whine.
It could be PSU or GPU.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
