26 minutes ago, Blackhole890 said:
because different psus are made by different components, otherwise there would not be any psu list or whatever or different prices... Usually, cheaper psus are made by cheaper components which leads to have less lifespan and get more stressed so it has more probabilities to stop working and take at least from one component to all your whole system down...
#1- You can have 600w psu and never upgrade until you run 2 r9 fury x for example. What i mean is that if he/she upgrades the gpu and his/her power supply does not give enough, he/she would need to buy a new psu... I don't mean to get the psu with highest watts possible but i suggest to get, at least, 500-600w.
#2- Save money huh? The intention wasn't bad but if you want to save money, save on cheaper gpu or ram but never on psu unless you want to have a firebomb in your house and after a year say bye to your computer...
Save money becuase of mail-inrebate........not becuase the PSU is a fireball
2 hours ago, RAM555789 said:
I know that the 80+ rating defines the quality of the parts used in a PSU, I'm not even going to bother opening that link becuase just reading the first sentence I can see where this is going. But What I don't get is the fact were both recommnding 80+ Bronze, which is an industry standard. I don't see how your saying one 80+ Bronze is a higher quality than another 80+ Bronze, the difference will come in wattage, and if the PSU is modular, semi-modular, or non-modular. I am suggesting the 430 watt becuase its #1 Meets the needed wattage for their build, and #2 Saves them a little money.
No it doesn't. The EVGA B2 is built better and performs better than the EVGA G1, a bronze and gold-rated unit respectively. If you read the thread he linked to (which is pinned on the PSU/Chassis subforum) then it would lead to you understanding the subject better.
There is more to PSU quality than their rated wattage output (which can be advertised deceitfully - look at a bunch of Raidmax units if you want a "700W" unit that can only output 400W of its advertised power) and efficiency. Want a really good 80 PLUS Bronze unit? Get an EVGA B2 or Seasonic S12. Want a really bad one? Get a Thermaltake TR2.
The minute difference in efficiency shouldn't lend to one's thinking that one unit is better than the other nor should it lend to the idea that it will be more energy-efficient to use X power supply over another. The only difference is a couple of watts of power wasted from the wall and exhausted out the back of the PSU.
I suggest you read up a bit before suggesting to others that they're wrong without any substantial proof.
I would go for 6GB GTX card or buy a RX 480 4GB! o3o
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
If had read what I am suggesting you would have seen I was vouching for a lower wattage PSU (the EVGA with 430w) and they were the on suggesting a higher wattage at 500-600w. So apparently me suggesting a lower 430w (thats an EVGA, which according to you is a good PSU) and them suggesting a 500-600w is me suggesting a 700w PSU? Where did you get that idea from? Another argument they have aginst mine is that it is "too cheap". Its $10 cheaper becuase of a mail in-rebate not that its normally priced different.
22 hours ago, N1ghtshade said:
https://pcpartpicker.com/list/ypk8vV
edit: What are you gonna use the pc for? Gaming? Video production? If anything besides gaming i'd recommend this
https://pcpartpicker.com/list/GzLjCy
Gaming and editing those videos
9 hours ago, Blackhole890 said:
1.- Better than the 1060 that you had chosen.
2.- It's a commercial name that gigabyte gave to it's gpu, don't get it because it gets very very hot.
3.-
PCPartPicker part list: https://pcpartpicker.com/list/K94jCy
Price breakdown by merchant: https://pcpartpicker.com/list/K94jCy/by_merchant/
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor  ($218.44 @ OutletPC)
Motherboard: MSI B350M GAMING PRO Micro ATX AM4 Motherboard  ($79.89 @ OutletPC)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory  ($63.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.88 @ OutletPC)
Video Card: MSI Radeon RX 480 4GB GAMING X Video Card  ($204.99 @ Jet)
Case: Zalman Z1 Neo ATX Mid Tower Case  ($29.99 @ Amazon)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($48.89 @ Newegg)
Wireless Network Adapter: TP-Link TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter  ($16.75 @ OutletPC)
Total: $710.82
Generated by PCPartPicker 2017-04-13 04:55 EDT-0400
4.- From the list that i gave you includes the recommended psu.
https://www.amazon.com/gp/aw/d/B01KCWZ1RW/ref=mp_s_a_1_139?ie=UTF8&qid=1492108071&sr=1-139&m=A2L77EE7U53NWQ&pi=AC_SX236_SY340_QL65#immersive-view_149210828174
is this one the same gpu? Nevermind
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
Ahhhhhh your grammar...
The 430W EVGA is not a very good PSU (thus it is cheap). Not all EVGA PSUs are good as EVGA doesn't actually manufacture them, so one can't just say "All EVGA PSUs are good." What incentive would there be to buy a higher-end unit like the G2 over the 500W White series?
So far, from what I can see you haven't helped OP much. So....
Here's a list for OP @Banish72
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($193.65 @ OutletPC)
Motherboard: MSI B150M ECO Micro ATX LGA1151 Motherboard  ($62.99 @ SuperBiiz)
Memory: G.Skill Aegis 8GB (1 x 8GB) DDR4-2133 Memory  ($52.99 @ Newegg)
Storage: PNY CS1311 120GB 2.5" Solid State Drive  ($49.99 @ Amazon)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($44.95 @ Amazon)
Video Card: Asus Radeon RX 480 4GB Dual Video Card  ($188.99 @ SuperBiiz)
Case: Deepcool TESSERACT WH ATX Mid Tower Case  ($37.99 @ SuperBiiz)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($53.99 @ Amazon)
Total: $685.54
Generated by PCPartPicker 2017-04-13 15:57 EDT-0400
I just realized that I have been reading the EVGA PSU as 80+ Bronze when its just 80+. I mean its got pretty good reviews, but I see the problem with it now. Having a fireguard shift from 2200-0000 coupled with learning CCNA does not help much with concentration. I'm drinking pre-work out that contains caffine to stay awake right now xD
Also about the wireless internet do I need to get that or can I just connect it straight to my router or modem? @STRMfrmXMN
5 hours ago, Banish72 said:
It's possible to reuse hard drives right? Cause I have 2 kinda old desktops already. @STRMfrmXMN
Yes, as long as they use SATA and you format them prior to using them as storage drives (this wipes all the data off of them in a somewhat secure way). This can be done during the Windows installation or after, doesn't matter.
If you want to use a router (AKA you need to use wireless internet) then you'll need the adapter. If you want wired internet (modem) then you plug the ethernet cable into your motherboard.
Ok cool thank you
3 hours ago, RAM555789 said:
I would use ethernet cable, I have had bad experiences with adpaters.
This is why you get a decent PCIe adapter and not a USB adapter or a really cheap one. The TP-Link WDN4800 is what I use in my desktop and I've built tons of systems using it specifically and have never had problems.
It was more of a wifi issue really, I could not get a good signal where I was, and even if I had it was only like 3mbps, comapred to 10mbps when downloading on steam. During a speed test I had 70mbps  though lol
