Hey! I just completed my new Ryzen build featuring the Ryzen 7 1700X but the CPU keeps overheating at stock speed(3.4Ghz) I'm using an AiO(Cooler Master Masterliquid lite 120) but it keeps overheating understand synthetic load the max it hit was 85°C and while Gaming it stays at 80°C please help...
Thanks
https://linustechtips.com/topic/765385-cpu-overheating/
1 minute ago, SenioRR said:
Did you overclock it? Check the thermal paste on the cooler. Check the fan speed for your AiO using Speedfan or in BIOS and increase it if needed. I don't think it should run this got unless overclocked or there is an issue with your AiO.
No I have not overclocked my CPU... and the fans are running at Max.RPM all the time
https://linustechtips.com/topic/765385-cpu-overheating/#findComment-9667502
https://linustechtips.com/topic/765385-cpu-overheating/#findComment-9667517
