I have a USB hub for my PC and I was trying to mount it to the bottom of my desk. I tried sticky tack, Tape, and that sticky stuff from those hooks you can hang up, and nothing seems to work. Any ideas would be great
CPU- Ryzen 9 3900x
CPU Cooler- Artic Liquid Freezer 2 240mm
GPU-  GIGABYTE AORUS GeForce RTX 3070 Ti Master 8G
RAM- CORSAIR VENGEANCE RGB PRO 32GB 3200Mhz
PSU- Cooler Master MasterWatt 650 Watt
HDD- WD Blue 4TB x2
SSD- 1TB WD Blue SN550 NVMe
Case- Custom Made Desk
Motherboard- ASUS ROG Strix B450-F Gaming
Microphone- Blue Snowball Ice
Headphones- Razer Nari Ultimate
Webcam- Logitech c270
Monitors- MSI Optix MAG24C and Acer KA240HQ Abid
Mouse- Corsair Nightsword RGB
Keyboard- Corsair K95 RGB Platinum MX Speed
https://linustechtips.com/topic/765316-usb-hub-mounting/
SUGRU
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/765316-usb-hub-mounting/#findComment-9666818
1 open the case of the hub
2 drill holes into the side that will attatch onto the desk
3 screw it into the desk
4 close the case
i like trains 🙂
https://linustechtips.com/topic/765316-usb-hub-mounting/#findComment-9666832
