You'll need three 8x slots. But why don't buy a 780 or something instead?
Edit: Atleast I think you need 8x... I have no idea lol
I personally don't enjoy 9-string guitars, but that doesn't change the fact that they look awesome as hell!
https://linustechtips.com/topic/76527-3-way-sli/#findComment-1050019
They'd all be running in PCI-E 4x speed if you do (I think), but if you actually want to, I don't see why not.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/76527-3-way-sli/#findComment-1050023
3-way SLI is the last resort. It would be much better to spend that amount of money on a single better card.
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
https://linustechtips.com/topic/76527-3-way-sli/#findComment-1050026
would running 3 660tis in pci x16x8x4 effect the proformance ?
would 3 660tis be anygood ?
i dont care about the sli problems in stuff
no, but they will all be running in 4x ,not one in 16x one in 8x and one in 4x...
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/76527-3-way-sli/#findComment-1050032
NVIDIA will not allow SLI to be enabled on a PCIe x4 slot, because they are NVIDIA.  You can use HyperSLI to hack around the limitation though.  3-way SLI is not very efficient though, I'd get a more powerful single or dual GPU solution, if it's cost effective to do so as an alternative.
https://linustechtips.com/topic/76527-3-way-sli/#findComment-1050035
