CPU plugd in wrong
Solved by BlueChinchillaEatingDorito,
Just now, PaaLaekker said:my question is will it damage anything when you used 4 pins from cpu1 and 4 pins from cpu2 -> 8pin on motherboard?
In theory it should be fine since fortunately, the Ground and Power pins aren't reversed or anything. But if he managed to plug one of the split connectors to CPU1 and the other to CPU2, I'm skeptical if he didn't manage to reverse it on the motherboard side (GRN to +12V or vice versa).
