Narrowed down an extremely high pitched noise which is coming from my Corsair ax760 power supply. The noise is present when the pc is in standby and being under heavy load doesn't make a difference. Is it coil whine? And if so is there anything I can do as it is hurting my ears.
https://linustechtips.com/topic/765098-coil-whine/
I know it's a "no-no" to open a PSU; however, you could (if you knew what you were doing) replace the internal fan. Otherwise, if you like to keep your heart beating and you're not sure what you'd be doing, there's not much for other options other than replacement or RMA depending on how old it is.
https://linustechtips.com/topic/765098-coil-whine/#findComment-9664332
I don't think the fan is causing it, as when the psu is in hybrid mode and the fan isn't spinning, there is still the noise.
https://linustechtips.com/topic/765098-coil-whine/#findComment-9664357
Sounds like coil whine, you could open it up, try to identify the offending part and encase it in silicone to limit the whine (careful of the lethal discharge) or replace the PSU. Be safe and just replace the PSU, check reviews on jonnyguru.com
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/765098-coil-whine/#findComment-9664391
AX series are known for coil whine
https://linustechtips.com/topic/765098-coil-whine/#findComment-9664454
Don't have any proof of purchase anymore unfortunately. Any recommendations for other manufacturers?
I use Corsair RMx 750, so that is what I would initially recommend. A couple friends have the same series, and we really do like them. I hear good things about some EVGA's, but there is a post that does have the PSU tier listing if you're interested:
Did you purchase online? If so, you can get proof of purchase from that. But it should also have a manufacture date, which could potentially be used if it's within the warranty coverage.
https://linustechtips.com/topic/765098-coil-whine/#findComment-9664458
Not online unfortunately. Read that corsair only do rma's if you have proof of purchase, so looking into a new unit seems like my only option.
https://linustechtips.com/topic/765098-coil-whine/#findComment-9664474
Most stores keep track of purchase history for 3-5 years. You could potentially go to the store and pull up the receipt The business I work for keeps track of that, and is accessible via  name, address, phone number or credit card if you still have the same card. If there is a will, there is a way.
https://linustechtips.com/topic/765098-coil-whine/#findComment-9664483
