Anyone know how I order cables from eNsourced.net? I've emailed him from his site and gave him my equipment list but no response. I'm assuming I'm being annoying by not knowing what to exactly ask for or how to use the e-commerce portion of his site, but dang. No idea how to proceed and this is the last piece of my build. This is my first PC so a little help would be appreciated on what I should be asking for and if these are the only cable I'd need. I'm only looking to dress up the cable that will be showing, if thats not obvious.. Thanks in advance.
EQUIPMENT
GPU: Nvidia Founders 1080ti  (1) 6-pin / (1) 8-pin
PSU: Corsair HX850i (24-pin?)
Mobo: Asus Maximus IX Hero
https://linustechtips.com/topic/764686-help-w-cables/
EQUIPMENT
You send them the design or pattern of your choice with the PSU in your system.
https://choosemypc.net/sleeving/
https://linustechtips.com/topic/764686-help-w-cables/#findComment-9659447
The cables in the photo that I attached. It's no worries though. I ordered some cables this evening and I think I got it right. Hope I did anyway.
1) 30cm 8-pin CPU/EPS
1) 30cm 24-pin Mobo
1) 40cm 8-pin PCI-e
1) 40cm 6-pin PCI-e
I'll be working inside an NZXT 340 elite so I think that order covers all of the visible cables. Anyway, thanks again for the help. Looking forward to getting this thing started.
https://linustechtips.com/topic/764686-help-w-cables/#findComment-9661664
1) 30cm 24-pin Mobo
1) 40cm 8-pin PCI-e
1) 40cm 6-pin PCI-e
I assume you're getting extensions then for the system since those would be fairly short if they are fully sleeved replacements.
https://linustechtips.com/topic/764686-help-w-cables/#findComment-9661674
I am... Is that a good or bad thing? Or neither? Here's the link to what I ordered:
http://www.ensourced.net/white-scale-paracord-sleeved-extensions/
1) 30cm 24-pin Mobo
1) 40cm 8-pin PCI-e
1) 40cm 6-pin PCI-e
https://linustechtips.com/topic/764686-help-w-cables/#findComment-9661686
Ok..But no connection loss or anything like that? I feel like an idiot for asking but this is my first build and first PC. I'm in tech, live on a MBP and game on a console, just looking for a change as I'm really bored with Apple and their sub-par hardware releases. Also bought an Oculus for UX research and I needed a machine like this. Appreciate the help.
https://linustechtips.com/topic/764686-help-w-cables/#findComment-9661696
No it doesn't cause any issues, and in the S340 you have a basement to hide any extra cable length fairly easily. And all the gadgets! :D
https://linustechtips.com/topic/764686-help-w-cables/#findComment-9661703
