clock speed
Go to solution Solved by tautvydas,
8 minutes ago, knightslugger said:
Is the Power management set to High Performance? That's usually why.
actually you were right, tired to put it on power saver and i saw it drop to 800 MHz , but my balanced one was bugged somehow, so i tired to reset it and i guess it fixed the problem now thanks !
so iv just noticed that my CPU clock speed is always at its max , no matter what i do. This was not the case even yesterday, usually id get 800-900 MHz when idle and then depending on work load, but now its allways at 3.8 GHz (boost clocked i guess)
i'm using realtemp 370 to see my temps and when it hit 65 while playing league and all windows open i just checked and this occurred, any ideas why and how ?
https://linustechtips.com/topic/764576-clock-speed/
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/764576-clock-speed/#findComment-9657986
If you have a fancy enough motherboard their's a BIOS setting that forces the CPU to run at boostclock speed 100% of the time. Though based off your story I doubt it's enabled.
https://linustechtips.com/topic/764576-clock-speed/#findComment-9657990
well i did not change anything, one weird thing occurred though, last night before i went to sleep, when i tried to turn off PC suddenly it blue screened, nothing unusual here , and today afternoon when i got back from college i tried to turn on but it was stuck on Welcome after i input password, so i just reseted with button
https://linustechtips.com/topic/764576-clock-speed/#findComment-9658009
https://linustechtips.com/topic/764576-clock-speed/#findComment-9658035
