Been having an issue with my PC crashing for about 4 days now. I've gone through what I think could be the issue including AMD's Audio Drivers conflicting with other audio drivers, my system getting too hot, my graphics card not sitting properly in the PCIe slot, etc. Still no luck. It's an intermittent issue but it's becoming a nuisance to have to deal with. The monitors turn black but remain on and there is a buzzing loop through the speakers if there was audio playing at the time of the crash.
System specs:
OS: Windows 10 Home 64-bit
CPU: Intel Xeon E3 1230 v5
Mobo: MSI Xeon E3 Krait Gaming v5
GPU: AMD R9 390x
RAM: 32GB Corsair Vengeance LPX DDR4
PSU: BeQuiet Dark Power Pro 11 850W
https://drive.google.com/open?id=0BxnKaZtyfOCDLWd5UVRhRU5sZms
Link is to the Sysnative BSOD dump. For some reason the PERFMON didn't finish running so that info can't be provided unfortunately.
https://linustechtips.com/topic/764506-pc-crashing-issue/
System specs:
GPU: AMD R9 390x
I'll take a look at the dump files in a few hours and post back with my findings.
EDIT:
@azraelkrieg Can you open up Explorer and navigate to "%SystemRoot%\Minidump\"  (Without quote marks). Is there a file called MEMORY.DMP? The sysnative output reports that a rather large dump file should be there, but due to its size, it has to be manually copied. Copy it to a folder on the desktop and try to zip it and share using google drive. Its roughly ~1,200Mb.
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
https://linustechtips.com/topic/764506-pc-crashing-issue/#findComment-9661024
EDIT:
Tried to get that before buy for some reason I get an error message saying it can't be found.
https://linustechtips.com/topic/764506-pc-crashing-issue/#findComment-9661323
Can you see the dump file in Explorer? If not, it may be possible that it has been deleted. This may be true if you run the disk cleanup utility.
https://linustechtips.com/topic/764506-pc-crashing-issue/#findComment-9661389
Nothing. And I don't tend to run the disk cleanup utility since my OS drive is an SSD.
https://linustechtips.com/topic/764506-pc-crashing-issue/#findComment-9661513
Unfortunately, I wont be able to help without those files. Strange that its gone. If your machine happens to BSOD hang or crash these net few days, post back here with the minidump or tag me in a post and I'll be more than happy to help.
https://linustechtips.com/topic/764506-pc-crashing-issue/#findComment-9661680
Sure thing. I did an update to the chipset drivers last night and I haven't encountered any issues yet. It's not BSOD'ing which is odd because the last time I had issues that involved it hanging or crashing it was accompanied with a BSOD saying Thread stuck in device driver.
https://linustechtips.com/topic/764506-pc-crashing-issue/#findComment-9661697
