Anyone have any idea why my cpu temp would all of a sudden start fluctuating like this ? I thought maybe my overclock settings( seems off due to the fact it's been the same for weeks with zero issues) so I dropped it back to stock and still it's like this. Also it seems to want to stay at core speed and core voltage even tho I'm set on balance mode. *NOTE* when I place power settings into power savings usage spikes to 60-70% this all started after play session. Never happened before. And both gpu temps are fine the system is on a custom loop and all 3 are tied into each other so I would see both gpus spiking if the system was over heating. Any ideas would be great
Intel I7 6700k
Z170-AR
https://linustechtips.com/topic/763967-cpu-temp-fluctuating-non-stop-need-help/
the spikes and dips follow you usage it is fine.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
How come it would all of a sudden start to do this ? Even at idle it wants to give near full voltage and keep it at 4.0 or 4.6ghz? (Depending on clock speed profile)
This is actually pretty normal for CPUs to spike in temp, especially when overclocked. The effect becomes more noticeable as the core voltage goes up. As long as it is not hitting the high 80s it is perfectly fine.
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
