Having trouble pinging a sub interface
Go to solution Solved by Lurick,
1 hour ago, Shammikit said:
-SNIP-
PC 2 has the wrong IP adddress and is in the wrong subnet. It should be 192.168.4.4, not 192.168.3.4.
i have two computers connected to a switch and that connected to a router.i have created vlans for the 2 computers as management and sales.then i have created sub interfaces at the router. using pc1 it is possible to ping the sub interface of it but im not able to ping the sub interface of pc2 using pc2. this is what i get in show running config.i have been stuck in this for several hours now and i couldnt find any solution to this in the internet.any help would be greatly appreciated.
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 100
ip address 192.168.2.1 255.255.255.224
interface GigabitEthernet0/0.2
encapsulation dot1Q 101
ip address 192.168.5.3 255.255.255.224
interface GigabitEthernet1/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet2/0
no ip address
duplex auto
speed auto
shutdown
--More--
https://linustechtips.com/topic/763669-having-trouble-pinging-a-sub-interface/
What do the PC configs look like?
Could you paste screenshots?
Also, what does the switch config look like for the ports connected to the PCs and the uplink?
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
-------------------------Router----------------------------------------
Router>en
Router#config t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#int gig0/0
Router(config-if)#no ip add
Router(config-if)#no shut
Router(config-if)#
%LINK-5-CHANGED: Interface GigabitEthernet0/0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to up
Router(config-if)#int gig0/0.100
Router(config-subif)#
%LINK-5-CHANGED: Interface GigabitEthernet0/0.100, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0.100, changed state to up
Router(config-subif)#encapsulation dot1q 100
Router(config-subif)#ip add 192.168.3.3 255.255.255.224
Router(config-subif)#int gig0/0.101
%LINK-5-CHANGED: Interface GigabitEthernet0/0.101, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0.101, changed state to up
Router(config-subif)#encapsulation dot1q 101
Router(config-subif)#ip add 192.168.3.5 255.255.255.224
% 192.168.3.0 overlaps with GigabitEthernet0/0.100
Router(config-subif)#ip add 192.168.4.5 255.255.255.224
Router(config-subif)#end
Router#
%SYS-5-CONFIG_I: Configured from console by console
Router#show run
Building configuration...
Current configuration : 902 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
no service password-encryption
hostname Router
ip cef
no ipv6 cef
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.100
 ip address 192.168.3.3 255.255.255.224
interface GigabitEthernet0/0.101
 ip address 192.168.4.5 255.255.255.224
 no ip address
 duplex auto
 speed auto
 shutdown
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial3/0
 no ip address
 shutdown
interface Serial4/0
 no ip address
 shutdown
interface Serial5/0
 no ip address
 shutdown
ip classless
ip flow-export version 9
-------------------------------------------Switch-------------------------------------------
Switch>enable
Switch#configure terminal
Switch(config)#vlan 100
Switch(config-vlan)#name management
Switch(config-vlan)#vlan 101
Switch(config-vlan)#name sales
Switch(config-vlan)#int range fa0/1-2
Switch(config-if-range)#switchport mode access
Switch(config-if-range)#spanning-tree portfast
%Warning: portfast should only be enabled on ports connected to a single
host. Connecting hubs, concentrators, switches, bridges, etc... to this
interface when portfast is enabled, can cause temporary bridging loops.
Use with CAUTION
%Portfast will be configured in 2 interfaces due to the range command
but will only have effect when the interfaces are in a non-trunking mode.
Switch(config-if-range)#int fa0/1
Switch(config-if)#switchport access vlan 100
Switch(config-if)#int fa0/2
Switch(config-if)#switchport access vlan 101
Switch(config-if)#int fa0/4
Switch(config-if)#switchport mode trunk
Switch(config-if)#
%LINK-5-CHANGED: Interface FastEthernet0/4, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/4, changed state to up
------------------------------PC1-------------------------
ip address: 192.168.3.2
subnet mask: 255.255.255.224
gateway: 192.168.3.3
--------------------------------pc2---------------------------------
ip address: 192.168.3.4
gateway: 192.168.4.5
-SNIP-
Prior Build Log/PC:
