Hello,im new to this forum and i need help for old hardware, i have a compaq presario 4016 (not hp compaq) and the motherboard kind of posts ,it starts to post but there are garbage letters all over the screen,and i want to know what is the problem, i cleaned the mobo and case, and i have a psu question that it has a 6 pin power connector for cpu ( not gpu neither my psu has 6 pin power for cpu, and my psu has a solid 24 pin power and the mobo needs 20 pin so can i plug the 4 pin cpu power to  6 pin cpu power and 24 pin mobo power to 20 pin power (the psu is out of a dell, a ac bel psu)
Edited by W-L
Text Color
PC Specs:Custom Built PC
CPU:AMD Ryzen 3 1200 GPU:Zotac GeForce GTX 1050 TI Mini RAM:Corsair Vengence 2400 MHz DDR4 Motherboard:ASUS Prime B350M-A AM4 Motherboard Case:Corsair 100R PSU:Corsair VS450
Laptop Specs:Acer TravelMate 8472
CPU:Intel Core i5 560M Memory:2GB DDR3 CPU:Intel HD Graphics Case:Its a Laptop Motherboard:Laptop Motherboard
https://linustechtips.com/topic/763555-old-hardware-help/
Can't find the computer online... Can you find a link or photo of it and post it?
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/763555-old-hardware-help/#findComment-9647355
https://linustechtips.com/topic/763555-old-hardware-help/#findComment-9647436
18 minutes ago, Gaurav S Rao said:
I have no idea what computer that is... If a photo of the motherboard or front of the case is possible please post it.
I do recognize the PSU though. Had one lying around from an old computer I scrapped.
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/763555-old-hardware-help/#findComment-9647498
this is either a compaq presario 4016/4026
it has a intel Pentium 3 450 mhz and uses 6 pin for cpu power,im pretty sure that's a asus board,the 4 pin fits,but im not sure if it's going to work since the psu was out of a dell pc i use that has issues,all 24 pins are solid but the first 20 fit and i doubt that the 24 pin would be a problem since the first 20 pins are electronically the same,only having doubts about the 6 pin
https://linustechtips.com/topic/763555-old-hardware-help/#findComment-9647543
