fan controller?
Solved by W-L,
1 hour ago, levi0jones said:-SNIP-
You can configure fan profiles using the motherboard's BIOS or software directly without having to get a fan controller. If you want an option however the NXT Grid+ V2 is good for 3 pin DC voltage control fans.
Issac Zachary ·
Posted in Troubleshooting1 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0 -
6
play_circle_filled
Latest From ShortCircuit:
