hey all!
first off, sorry for shitty english..
i am currently rocking this setup:
Intel Core I5 3570k - Coolermaster Seidon 120XL
Asrock Z77E-ITX
EVGA GTX 770 Superclocked ACX
Kingston HyperX 16gb 1600 MHz
XFX core PRO550W
Bitfenix Prodigy
Samsung 840 250gb SSD
Kingston V300 120gb SSD
2tb HDD
and for some time now i have been saving and wanting to do an upgrade.
i have always been very interested in custom watercooling, but never had the guts or money to try it out. This i want to change!
My plans for upgrade are as follows:
change gpu to 1080 (havent decided which yet)
change case to Phanteks Enthoo Evol Itx in white.
I really want to make an all white/black build, with black fittings, clear tubing and white liquid. i want to make it as clean and esthetically pleasing as possible.
some questions:
if i want to go custom watercooling, should i just get the cheapest 1080 and throw on a waterblock? or should i still go for a decent 1080?
Should i upgrade my 3570k and mobo too, to reduce bottlenecking, or can it still do enough to not hold back a 1080?
thoughts and concerns? will make a build log if people want me to :)
Upgrade CPU if you get 1080.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
unless you wanna play 4k, you should get something like rx 480 for 1080p (or 1070 for 2k)
11 minutes ago, ande8118 said:
some questions:
1.- if i want to go custom watercooling, should i just get the cheapest 1080 and throw on a waterblock? or should i still go for a decent 1080?
2.- Should i upgrade my 3570k and mobo too, to reduce bottlenecking, or can it still do enough to not hold back a 1080?
1.- just get the cheapest 1080 (but never get the founders edition) since the only difference are their speeds and its about 100mhz more or less, which it wont affect your gameplay experience
2.- you can get used 3770k and with an oc, your  cpu wont bottleneck your gpu
depending on which games is he going to play... If its gpu bound, the cpu upgrade would be a waste
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
i mostly play Overwatch, BF3 and the like :)
so maybe i should look for used i7 3770k?
and just get cheapest non-reference 1080?
am playing in1080p now, planning on going to 1440p :) i want to go to 1080 so it will last me longer
1 hour ago, ande8118 said:
I'd say no, unless your heart set on playing in 4k, since a 1070 can do 1440p easily.
Current System Specs:
CPU: Intel I5-7660K; CPU Cooler: Coolermaster Hyper 212X; Thermal Paste: IC Diamond 7 Carat; Motherboard: MSI Z270 Gaming Pro Carbon;
RAM: Kingston HyperX Fury Black 16GB (2 x 8gb) DDR4 - 2400; SSD Storage: 1TB Samsung 850 EVO; Storage: 2TB Seagate Barracuda 7200rpm;
GPU: Gigabyte Geforce GTX 1070 8gb G1 Gaming; Case: NZXT Phantom 530 Black; PSU: EVGA Supernova G2 650W 80+ Gold, OS: Windows 10 Home
