Advice for my PC build
I have found out the following hardware parts for my PC build:
Motherboard: Gigabyte GA-H110M-S2
GPU: Zotac Geforce GTX 1050 Ti 4GB OC edition
RAM: Hyperx Fury 8GB DDR4 2133 MHz
CPU: Intel G4560 Pentium Dual Core LGA1151
PSU: Corsair VS450
Cabinet: Corsair Spec-01 carbide series
HDD: WD 1TB 7200RPM
Kindly suggest me to go for this build or not.
Motherboard: Make sure it supports Kaby Lake.  Not all H110 Chipset boards do.  If it doesn't support Kaby Lake, then you may have to spend a bit more money on a motherboard that does support Kaby Lake.  You could also spend a bit more to get an i3-6100, instead.
GPU: If you can spend a little more and get an RX 470, that would be great.  If not, then that 1050 Ti is fine.
RAM: Good.
CPU: Good, as long as the motherboard supports it.
PSU: Good.
Case: Excellent choice! :D
HDD: Good.
Sorry for the mess!  My laptop just went ROG!
"THE ROGUE":  ASUS ROG Zephyrus G15 GA503QR (2021)
  • Ryzen 9 5900HS
  • RTX 3070 Laptop GPU (80W)
  • 24GB DDR4-3200 (8+16)
  • 2TB SK Hynix NVMe (boot) + 2TB Crucial P2 NVMe (games)
  • 90Wh battery + 200W power brick
  • 15.6" 1440p 165Hz IPS Pantone display
  • Logitech G603 mouse + Logitech G733 headset
"Hex": Dell G7 7588 (2018)
  • i7-8750H
  • GTX 1060 Max-Q
  • 16GB DDR4-2666
  • 1TB SK Hynix NVMe (boot) + 2TB Crucial MX500 SATA (games)
  • 56Wh battery + 180W power brick
  • 15.6" 1080p 60Hz IPS display
  • Corsair Harpoon Wireless mouse + Corsair HS70 headset
"Mishiimin": Apple iMac 5K 27" (2017)
  • i7-7700K
  • Radeon Pro 580 8GB (basically a desktop R9 390)
  • 16GB DDR4-2400
  • 2TB SSHD
  • 400W power supply (I think?)
  • 27" 5K 75Hz Retina display
  • Logitech G213 keyboard + Logitech G203 Prodigy mouse
Other tech: Apple iPhone 14 Pro Max 256GB in White, Sennheiser PXC 550-II, Razer Hammerhead earbuds, JBL Tune Flex earbuds, OontZ Angle 3 Ultra, Raspberry Pi 400, Logitech M510 mouse, Redragon S113 keyboard & mouse, Cherry MX Silent Red keyboard, Cooler Master Devastator II keyboard (not in use), Sennheiser HD4.40BT (not in use)
Retired tech: Apple iPhone XR 256GB in Product(RED), Apple iPhone SE 64GB in Space Grey (2016), iPod Nano 7th Gen in Product(RED), Logitech G533 headset, Logitech G930 headset, Apple AirPods Gen 2 and Gen 3
Trash bin (do not buy): Logitech G935 headset, Logitech G933 headset, Cooler Master Devastator II mouse, Razer Atheris mouse, Chinese off-brand earbuds, anything made by Skullcandy
